11 years 6 months ago #818
by jnissen
I have activities this weekend after all. I may have some time this afternoon.
- ThibmoRozier
11 years 6 months ago #819
by ThibmoRozier
Just give me a notification when you are able to.
I think I have most of my contact details within my profile.
- ThibmoRozier
11 years 6 months ago - 11 years 6 months ago #842
by ThibmoRozier
I really wish I had an option to show the raw data from the GMC, but maybe this will do.
class gmc(baseGeigerCommunication):
def initCommunication(self):
print "Initializing GMC protocol communication => geiger 1\r\n"
# get firmware version
self.serialPort.flushInput()
self.serialPort.write("<GETVER>>")
# assume that device responds within 1s
time.sleep(1)
response=""
while (self.serialPort.inWaiting()>0 and self.stopwork==0):
response = response + self.serialPort.read()
# response=self.sendCommand("< GETVER >>")
if len(response)>0:
print "Found GMC-compatible device, version => geiger 1: ", response, "\r\n"
# get serial number
# serialnum=self.sendCommand("<GETSERIAL>>")
# serialnum.int=struct.unpack('!1H', serialnum(7))[0]
# print "Device Serial Number is: ", serialnum.int
# disable heartbeat, we will request data from script
self.serialPort.write("<HEARTBEAT0>>")
# self.sendCommand("< HEARTBEAT0 >>")
print "Please note data will be acquired once per 5 seconds => geiger 1\r\n"
# update the device time
self.serialPort.write("<GETDATETIME>>")
time.sleep(1)
unitTime=""
unitTime = unitTime + self.serialPort.read()
# unitTime=self.sendCommand("< GETDATETIME >>")
time.sleep(0.5)# just to ensure all CPM bytes are in serial port buffer
print "Unit shows time as => geiger 1: ", unitTime, "\r\n"
# self.sendCommand("<SETDATETIME[" + time.strftime("%y%m%d%H%M%S") + "]>>")
# print "<SETDATETIME[" + time.strftime("%y%m%d%H%M%S") + "]>>"
else:
print "No response from device => geiger 1\r\n"
self.stop()
sys.exit(1)
def getData(self):
cpm=-1
response=""
try:
# wait, we want sample every 30s
for i in range(0,3):
time.sleep(1)
# send request
self.serialPort.write("<GETCPM>>")
time.sleep(1)
# response=self.sendCommand("< GETCPM >>")
# wait for data
time.sleep(0.5) # just to ensure all CPM bytes are in serial port buffer
if len(response)==2:
# convert bytes to 16 bit int
msb = int(response[0]) & 0x3F
lsb = int(response[1]) & 0xFF
cpm = int((msb << 8) | lsb)
elif len(response) > 2:
edata=""
for i in range(1,len(response)):
edata = edata + ord(response[0])*256+ord(response[i])
cpm = int( ( float(edata) / ( len(response) - 1 ) ) +0.5)
else:
edata=""
print "Unknown response to CPM request, device is not GMC-compatible? => geiger 1\r\n"
print "Data recieved was: ",str(edata),"\r\n"
except Exception as e:
print "\r\nProblem in getData procedure (disconnected USB device?) => geiger 1:\r\n\t",str(e),"\r\nExiting\r\n"
self.stop()
sys.exit(1)
utcTime=datetime.datetime.utcnow()
data=[cpm, utcTime]
return data
Last edit: 11 years 6 months ago by ThibmoRozier.
11 years 6 months ago - 11 years 6 months ago #854
by jnissen
I can give this a try a bit later today. I have also been thinking about running "miniterm.py" on the BBB and manually entering in the commands and seeing what responses come back. If I can get that to work I will post the results.
UPDATE:
I was able to run miniterm on the BBB with the following command
debian@beaglebone:~/RadMon$ miniterm.py -b 57600 -p /dev/ttyUSB0 -e -D
--- Miniterm on /dev/ttyUSB0: 57600,8,N,1 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
<GETVER>>GMC-300Re 2.36
<GETCPM>>\x00\x18<GETCPM>>\x00\x16
I had ECHO on as well as the debug so I could see the data coming back after a command. As soon as the second ">>" is presented to the GMC unit it returns the data. I hit the enter key after the <GETVER>> or it would have been on the same line.
So the data appears to be returned but it's not ASCII that is for sure so it may be the handler in the python script is having a bit of difficulty.
I then submitted a bunch of commands and they seem to have some variable delay in the response. It would respond within milliseconds to as much as 1 second. The delay seems to be variable. Odd since I am manually submitting the commands but the response back is defiantly not consistent.
Here is an example of the returned data. I hit enter after each response so it would read better.
<GETCPM>>\x00\x13
<GETCPM>>\x00\x14
<GETCPM>>\x00\x15
<GETCPM>>\x00\x15
<GETCPM>>\x00\x14
<GETCPM>>\x00\x14
<GETCPM>>\x00\x15
<GETCPM>>\x00\x15
<GETCPM>>\x00\x15
<GETCPM>>\x00\x14
<GETCPM>>\x00\x13
<GETCPM>>\x00\x13
<GETCPM>>\x00\x12
<GETCPM>>\x00\x12
<GETCPM>>\x00\x13
<GETCPM>>\x00\x14
<GETCPM>>\x00\x14
<GETCPM>>\x00\x14
<GETCPM>>\x00\x16
<GETCPM>>\x00\x16
<GETCPM>>\x00\x16
<GETCPM>>\x00\x16
<GETCPM>>\x00\x16
<GETCPM>>\x00\x17
As for the latest code you added:
UPDATE:
<GETCPM>>\x00\x13
<GETCPM>>\x00\x14
<GETCPM>>\x00\x15
<GETCPM>>\x00\x15
<GETCPM>>\x00\x14
<GETCPM>>\x00\x14
<GETCPM>>\x00\x15
<GETCPM>>\x00\x15
<GETCPM>>\x00\x15
<GETCPM>>\x00\x14
<GETCPM>>\x00\x13
<GETCPM>>\x00\x13
<GETCPM>>\x00\x12
<GETCPM>>\x00\x12
<GETCPM>>\x00\x13
<GETCPM>>\x00\x14
<GETCPM>>\x00\x14
<GETCPM>>\x00\x14
<GETCPM>>\x00\x16
<GETCPM>>\x00\x16
<GETCPM>>\x00\x16
<GETCPM>>\x00\x16
<GETCPM>>\x00\x16
<GETCPM>>\x00\x17
python PyRadmon.py
Reading configuration:
User name configured
Password configured
Serial port name configured
Serial port speed configured
Protocol configured
Device number configured
Protocol configured
Using GMC protocol for 1 => geiger 1
Gathering data started => geiger 1
Found GMC-compatible device, version => geiger 1: GMC-300Re 2.36
invalid literal for int() with base 10: ''
Exiting
Waiting and reap threads
Last edit: 11 years 6 months ago by jnissen.
11 years 5 months ago #906
by jnissen
OK I had some more time to play with this. I have it communicating with the GMC detector and the Beagle Bone Black fairly well. It ran at least 8 hours without any errors. I am not convinced that the thing is communicating outside since I do not see my count update on the site. Is there an easy way to see if the communication back to the main server is OK? Here is a standard response:
I see an OK so is that all I should see? How long does it need to run before the site updates and recognizes it?
Waiting 30 seconds => geiger 1
Geiger sample => geiger 1: CPM = 17 2015-03-19 02:07:38.516733
Geiger sample => geiger 1: CPM = 20 2015-03-19 02:07:42.525041
Geiger sample => geiger 1: CPM = 19 2015-03-19 02:07:46.535699
Geiger sample => geiger 1: CPM = 18 2015-03-19 02:07:50.546573
Geiger sample => geiger 1: CPM = 18 2015-03-19 02:07:54.557623
Geiger sample => geiger 1: CPM = 19 2015-03-19 02:07:58.568534
Geiger sample => geiger 1: CPM = 19 2015-03-19 02:08:02.580153
Average result => geiger 1: CPM = 18 2015-03-19 02:08:02.580153
Connecting to server => geiger 1
Sending average sample => geiger 1: 18 CPM
Server response => geiger 1: HTTP/1.1 200 OK
11 years 5 months ago #908
Replied by mw0uzo on topic PyRadmon install and set up on Raspberry Pi (Wheezy Raspbian)
I will check the logs to see if your user/pass are correct etc
Time to create page: 0.199 seconds
