11 years 6 months ago #789 by ThibmoRozier
Cool, hope it will be fixed now :cheer:
Stuff like that tends to be done in firmware because its all low level asm. Using spare bits for adding in functions on top of older code etc. The and-or mask is a classic, ever wonder how 'sprites' were plotted on top of backgrounds without a nasty rectangular block around them?
True true.
Yet they send the datetime in a unmasked format... but cpm in a masked manner... >.<
Confusing stuff...
But it's just a mater of accepting and going on with trying to fix it, in the end-user product. :)
//Footnote: I wish DX_MON was more interested in this field, she's a genius programmer on firmware and end-user level.. Been trying to involve her into this, but egh, too busy. :P
11 years 6 months ago #790 by jnissen
DO I only change the gmc class or anything else? I am going to apply this in an hour or two. I have to run out now. The Main is as you sent earlier.
11 years 6 months ago #791 by ThibmoRozier
Sorry... Yes indeed.
I wish there was an ability to test it on my side.. Will see if I can create a simulator for it, or something in that area.. But for now, sorry for these changes.
All I am really going to change for now is the GMC class. { class gmc(...): }
11 years 6 months ago #792 by jnissen
Not quite...
Reading configuration:
User name configured
Password configured
Serial port name configured
Serial port speed configured
Protocol configured
Device number configured
Protocol configured
Using GMC protocol for 1 => geiger 1
Gathering data started => geiger 1
Initializing GMC protocol communication => geiger 1
Found GMC-compatible device, version => geiger 1: GMC-300Re 2.36
Please note data will be acquired once per 5 seconds => geiger 1
Unit shows time as => geiger 1:
Problem in getData procedure (disconnected USB device?) => geiger 1:
unsupported operand type(s) for &: 'str' and 'int'
Exiting
Waiting and reap threads
11 years 6 months ago #795 by ThibmoRozier
Not quite...
Password configured
Protocol configured
Protocol configured
Exiting
Hmm....
One small change, then I go to my studies, with coffee.
Please try the following.
The only change is the gmc class
class gmc(baseGeigerCommunication):
    def initCommunication(self):
        print "Initializing GMC protocol communication => geiger 1\r\n"
        # get firmware version
        self.serialPort.flushInput()
        self.serialPort.write("<GETVER>>")
        # assume that device responds within 1s
        time.sleep(1)
        response=""
        while (self.serialPort.inWaiting()>0 and self.stopwork==0):
            response = response + self.serialPort.read()
        # response=self.sendCommand("< GETVER >>")
        if len(response)>0:
            print "Found GMC-compatible device, version => geiger 1: ", response, "\r\n"
            # get serial number
            # serialnum=self.sendCommand("<GETSERIAL>>")
            # serialnum.int=struct.unpack('!1H', serialnum(7))[0]
            # print "Device Serial Number is: ", serialnum.int
            # disable heartbeat, we will request data from script
            self.serialPort.write("<HEARTBEAT0>>")
            # self.sendCommand("< HEARTBEAT0 >>")
            print "Please note data will be acquired once per 5 seconds => geiger 1\r\n"
            # update the device time
            self.serialPort.write("<GETDATETIME>>")
            time.sleep(1)
            unitTime=""
                unitTime = unitTime + self.serialPort.read()
            # unitTime=self.sendCommand("< GETDATETIME >>")
            time.sleep(0.5)# just to ensure all CPM bytes are in serial port buffer
            print "Unit shows time as => geiger 1: ", unitTime, "\r\n"
            # self.sendCommand("<SETDATETIME[" + time.strftime("%y%m%d%H%M%S") + "]>>")
            # print "<SETDATETIME[" + time.strftime("%y%m%d%H%M%S") + "]>>"
        else:
            print "No response from device => geiger 1\r\n"
            self.stop()
            sys.exit(1)
    def getData(self):
        cpm=-1
        response=""
        try:
            # wait, we want sample every 30s
            for i in range(0,3):
                time.sleep(1)
            # send request
            self.serialPort.write("<GETCPM>>")
            time.sleep(1)
            # response=self.sendCommand("< GETCPM >>")
            # wait for data
            time.sleep(0.5) # just to ensure all CPM bytes are in serial port buffer
            if len(response)==2:
                # convert bytes to 16 bit int
                msb = (hex(response[0]) & hex(0x3F))
                lsb = (hex(response[1]) & hex(0xFF))
                cpm = int((msb << 8) | lsb)
            elif len(response) > 2:
                edata=""
                for i in range(1,len(response)):
                    edata = edata + ord(response[0])*256+ord(response[i])
                cpm = int( ( float(edata) / ( len(response) - 1 ) ) +0.5)
            else:
                edata=""
                print "Unknown response to CPM request, device is not GMC-compatible? => geiger 1\r\n"
                print "Data recieved was: ",str(edata),"\r\n"
        except Exception as e:
            print "\r\nProblem in getData procedure (disconnected USB device?) => geiger 1:\r\n\t",str(e),"\r\nExiting\r\n"
            self.stop()
            sys.exit(1)
        utcTime=datetime.datetime.utcnow()
        data=[cpm, utcTime]
        return data
11 years 6 months ago #797 by jnissen
Seems we are fighting a data type issue. Perhaps if the data were considered binary can Python handle that? Bitwise logical operations are easy in assembly and C but seems this is difficult in Python. I must tell you I have little to no Python experience so I do appreciate the assistance.
        Password configured
        Protocol configured
        Protocol configured
        hex() argument can't be converted to hex
Exiting
Time to create page: 0.224 seconds
Solar powered Raspberry Pi 4 server stats: CPU 62% Memory 13% Swap 17% CPU temp=63.3'C Uptime 17 Days
