11 years 6 months ago #798 by ThibmoRozier
Seems we are fighting a data type issue. Perhaps if the data were considered binary can Python handle that? Bitwise logical operations are easy in assembly and C but seems this is difficult in Python. I must tell you I have little to no Python experience so I do appreciate the assistance.
Reading configuration:
        User name configured
        Password configured
        Serial port name configured
        Serial port speed configured
        Protocol configured
        Device number configured
        Protocol configured
Using GMC protocol for 1 => geiger 1
Gathering data started => geiger 1
Initializing GMC protocol communication => geiger 1
Found GMC-compatible device, version => geiger 1:  GMC-300Re 2.36
Please note data will be acquired once per 5 seconds => geiger 1
Unit shows time as => geiger 1:
Problem in getData procedure (disconnected USB device?) => geiger 1:
        hex() argument can't be converted to hex
Exiting
Waiting and reap threads
sooo....
I made a veeeeeeeery basic self-tester.
Now I finally got an answer for you. :)
Selftest:
#!/usr/bin/python
import sys
import time
response = 0x01, 62
if len(response)==2:
    # convert bytes to 16 bit int
    msb = (response[0] & 0x3F)
    lsb = (response[1] & 0xFF)
    cpm = int((msb << 8) | lsb)
    print(msb, lsb, cpm)
sys.exit(0)
Now that makes it easier for me to fix the code. :)
This gives me an output like :
>>> ================================ RESTART ================================
(1, 62, 318)
Then I apply this to the whole code and...
For as far as I can think of, this will be the code. :)
class gmc(baseGeigerCommunication):
    def initCommunication(self):
        print "Initializing GMC protocol communication => geiger 1\r\n"
        # get firmware version
        self.serialPort.flushInput()
        self.serialPort.write("<GETVER>>")
        # assume that device responds within 1s
        time.sleep(1)
        response=""
        while (self.serialPort.inWaiting()>0 and self.stopwork==0):
            response = response + self.serialPort.read()
        # response=self.sendCommand("< GETVER >>")
        if len(response)>0:
            print "Found GMC-compatible device, version => geiger 1: ", response, "\r\n"
            # get serial number
            # serialnum=self.sendCommand("<GETSERIAL>>")
            # serialnum.int=struct.unpack('!1H', serialnum(7))[0]
            # print "Device Serial Number is: ", serialnum.int
            # disable heartbeat, we will request data from script
            self.serialPort.write("<HEARTBEAT0>>")
            # self.sendCommand("< HEARTBEAT0 >>")
            print "Please note data will be acquired once per 5 seconds => geiger 1\r\n"
            # update the device time
            self.serialPort.write("<GETDATETIME>>")
            time.sleep(1)
            unitTime=""
                unitTime = unitTime + self.serialPort.read()
            # unitTime=self.sendCommand("< GETDATETIME >>")
            time.sleep(0.5)# just to ensure all CPM bytes are in serial port buffer
            print "Unit shows time as => geiger 1: ", unitTime, "\r\n"
            # self.sendCommand("<SETDATETIME[" + time.strftime("%y%m%d%H%M%S") + "]>>")
            # print "<SETDATETIME[" + time.strftime("%y%m%d%H%M%S") + "]>>"
        else:
            print "No response from device => geiger 1\r\n"
            self.stop()
            sys.exit(1)
    def getData(self):
        cpm=-1
        response=""
        try:
            # wait, we want sample every 30s
            for i in range(0,3):
                time.sleep(1)
            # send request
            self.serialPort.write("<GETCPM>>")
            time.sleep(1)
            # response=self.sendCommand("< GETCPM >>")
            # wait for data
            time.sleep(0.5) # just to ensure all CPM bytes are in serial port buffer
            elif len(response) > 2:
                edata=""
                for i in range(1,len(response)):
                    edata = edata + ord(response[0])*256+ord(response[i])
                cpm = int( ( float(edata) / ( len(response) - 1 ) ) +0.5)
            else:
                edata=""
                print "Unknown response to CPM request, device is not GMC-compatible? => geiger 1\r\n"
                print "Data recieved was: ",str(edata),"\r\n"
        except Exception as e:
            print "\r\nProblem in getData procedure (disconnected USB device?) => geiger 1:\r\n\t",str(e),"\r\nExiting\r\n"
            self.stop()
            sys.exit(1)
        utcTime=datetime.datetime.utcnow()
        data=[cpm, utcTime]
        return data
What did we learn from this:
Frameworks are to make your work easier, just keep it simple!
11 years 6 months ago - 11 years 6 months ago #799 by jnissen
Ha ha! I will let you know how it works tonight. Need to get home and try it out.
Update... Not sure If I have something wrong but still see this error. I can send you my detector and BBB if that helps.
        Password configured
        Protocol configured
        Protocol configured
        unsupported operand type(s) for &: 'str' and 'int'
Exiting
Last edit: 11 years 6 months ago by jnissen.
11 years 6 months ago #800 by ThibmoRozier
        Password configured
        Protocol configured
        Protocol configured
Exiting
Maybe it'd be better to set-up a teamviewer session on a scheduled moment.
I am available in about 3 hours, and then for about 8 hour long.
Would be rather easy to fix these issues then.
11 years 6 months ago #802 by jnissen
Can not do anything at the moment. Family stuff tonight. I may have time later this week. In the mean time I am going to see if I can get the BBB to talk over WiFi.
The following user(s) said Thank You: ThibmoRozier
11 years 6 months ago #813 by Juzzie
put that gmc in the recycling bin!!! aarrr!
11 years 6 months ago #815 by ThibmoRozier
Maybe on Saturday?
Could do for me.
Time to create page: 0.256 seconds
Solar powered Raspberry Pi 4 server stats: CPU 62% Memory 14% Swap 17% CPU temp=63.7'C Uptime 17 Days
