Problem with software
7 years 7 months ago #4300 by mw0uzo
Replied by mw0uzo on topic Problem with software
Ok interesting, thanks for doing this. Are there any settings to modify what unit the GMC500 reports?
For GMC500 users who are stuck while this is being fixed, you can connect the GMC500 audio click output to your PC audio input and use RadLog in audio mode.
I had a look through the manual and didn't see anything, so something must be slightly different with the data sent back by the GMC500.
7 years 7 months ago #4301 by mw0uzo
I am ordered new GMC320 + version 5, hope will work with software and will sell gmc 500. grr
Marco
Annoying, with a bit of luck we can identify what has changed and get it working...
7 years 7 months ago #4302 by s52sk
Replied by s52sk on topic Problem with software
Hi. Mw0uzo, if you wish i can send you my gmc500 that you should investigate it.
And than send the item back. I will received gmc320+ ver 5 at fraiday this week.
Marco
7 years 7 months ago #4303 by s52sk
Here you can see that gmc500 working well with GQ gmc data viewer
http://www.s52sk.com/kasiopeja/radiation.html
Marco
7 years 7 months ago - 7 years 7 months ago #4304 by mw0uzo
Ok we can do this as a last resort, we should be able to get it working without having to do this.
meteopedara, s52sk, see if you can get this to work with your GMC500:
Set GMC500 to 57600 baud in settings menu
Establish comms with the GMC500 in RealTerm at baud rate 57600
Confirm by typing <GETVER>>
Immediately type <GETCPM>>
The counter will return 16 bits of data according to the specification, i.e. 2 characters. Copy and paste these two characters into
https://www.rapidtables.com/convert/number/ascii-to-hex.html
That will give us two bytes of hex, which can then be converted to a decimal 16 bit number here https://www.rapidtables.com/convert/number/hex-to-decimal.html
That number should correspond with the CPM value on the screen at the time of <GETCPM>>
If more than 2 characters are returned, the specification has changed and it should be simple to work it out.
If the number is larger than expected, it's in a different unit or format.
If the number matches the CPM but RadLog reports wrong, its a bug or settings problem in RadLog.
Please post the two characters, or whatever is returned to the forum so I can inspect them.
Last edit: 7 years 7 months ago by mw0uzo.
7 years 7 months ago #4305 by s52sk
My comport information said: COM5,115200,n,8,1
This is info what I get out... If helps?
Marco
Solar powered Raspberry Pi 4 server stats: CPU 59% Memory 15% Swap 18% CPU temp=63.7'C Uptime 17 Days
