ESPGeiger
1 year 4 months ago - 1 year 4 months ago #7323
Replied by ChrisLX200 on topic ESPGeiger
Yes V.7, I only tried 0.6.x a couple of times but that didn't work either. I've been trying to get the code into Ardunio IDE by installing all the libraries but the 1306 library used is a bit of an odd one and I can't find that in library manager. Arduino IDE might seem a few steps backward but at least I can make sense of it, platformio the code is all over the place and I find it difficult to follow. I can get the automatic build/upload of the cloned github to work under platformio of course but making alterations to the code is a struggle. I'll be really interested in your findings with an ESP32.
Last edit: 1 year 4 months ago by ChrisLX200.
1 year 4 months ago #7330
I tried installing ESPGeiger on an ESP32 dev board and got exactly the same result. It installed, but then went into reboot cycles. Earlier I installed ESPGeiger on an ESP8266 and that was flawless.
00:00:15 ___
00:00:15 \_/ Starting up ... ESPGeiger-37f494
00:00:15 .--.O.--. Version - v0.7.0/db5f3a8 (ESP32)
00:00:15 \/ \/
*wm:AutoConnect
*wm:No wifi saved, skipping
*wm:AutoConnect: FAILED for 103 ms
00:00:15 WiFi not connecting ... Restarting ...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1344
load:0x40078000,len:13936
load:0x40080400,len:3600
entry 0x400805f0
The following user(s) said Thank You: ChrisLX200
1 year 4 months ago - 1 year 4 months ago #7332
Thanks for that info, at least it's not all my fault then
I'll try comparing the ESP32 with ESP8266 startup code and see if there's a difference that stands out. I know now I could get the boards working with 8266's but they're all cased with ESP32's attached and I would hate to remake them all.
Edit: I went back as far as V.5 bin files - which didn't work either but for a different reason - and after more poking around in the code I get the feeling this was never actually tested on an ESP32... Definitely not optimised anyway, e.g., it's using SoftwareSerial lib which is not necessary for ESP32 as it has 3 hardware serial ports. Anyway, I'm leaving it until such time as the author provides an update. I have ordered some Wemos D1 boards to play with so maybe I can lash something together just to get the 3 counters working/uploading.
1 year 4 months ago #7336
Yes V.7 works on the 8266 boards I purchased.
1 year 4 months ago #7339
I ordered some small 0.96" IIC OLED displays for the ESP8266 boards, I do like to be able to quickly read what each is doing. Cheap as chips at only £1.50 each. I can just cut a new top layer acrylic cover to suit and keep the original ones in case the ESP32 code is ever fixed. I'm having no luck with it.
I ordered the new laser machine yesterday so the hobby fund is well and truely spent up for a while...
Time to create page: 0.200 seconds
