Report measurements to APRS via internet (only internet,not HF)
4 years 8 months ago - 4 years 8 months ago #5953 by DG5BAA
Hello !
I am a newbie an i have a GMC-300E+.I am using the last Version of RadLog Pro 0.43 and would like to tranfer the measured data to APRS,but
somehow it doesnt work,why could it be ?
I can see my data in the radmon.org map but not in the map of aprs.fi ?
I am using a AVM 7490 Fritzbox and it set to: independent port sharing is switched on...
I
I use Win10 and the APRS TCP Port is open..
How can I check a broadcast in the aprs network?
Please help !
Thank you very much !
Carsten ,DG5BAA
Last edit: 4 years 8 months ago by DG5BAA.
4 years 8 months ago #5954 by mw0uzo
Ok, the data goes out via HTTP request, so you won't need to open any ports, assuming 80 is already open.(I will double check this)
You need to enter your callsign into Callsign box
Then use https://apps.magicbug.co.uk/passcode/index.php/passcode
To generate a Key code from your callsign. Enter this into Key box.
A default SSID of 0 will be fine.
Then Tick Report measurements to APRS via internet
4 years 8 months ago - 4 years 8 months ago #5958 by DG5BAA
Hello !
I have checked that the Port 80 is open - all OK
I have checked my call and passkey for APRS - all OK
(I can see my position in aprs.fi with the handy app for Android APRSDruid)
I can yee my radon.log measurements in the log map - all OK
I use the server: euro.aprs2.net - all OK i think
I useWin10 and Framework 4.7 - Must i install Windows 7 with Framework 4 ?
I have made the firewall off for Testing in Windows10 - and test with a online TCP Scanner that the Port 80 is open - all OK
Report measurement ist clicked on - OK
I test other SSIDs too like DG5BAA SSID 3 etc.
The only ive ssen that the koordinates in the mask are not working but there is a other topic in this forum  (.dezimal point) - all OK ?
Must i use a external GPS-mouse for Windows ?
What can it be ?-
Radlog 0.43 ist a very fine and useful program for me... :)
Thank you for every ideo and help - sorry for my english....
I73 and 55
Carsten
4 years 8 months ago #5959 by mw0uzo
Ok Carsten
I will set my counter up today with Radlog and check it, double check settings etc. Something might have changed...
The following user(s) said Thank You: DG5BAA
4 years 8 months ago - 4 years 8 months ago #5960 by DG5BAA
Hello mw0uzo !
Ive contact to the User Alex and he is writing that your fine software 0.43 was very easy to install and worked very fine about a long time with WIN7.
But now he has  RadLog a few month not in  use because there is a problem with his hardware.
Ive seen his measurements in the aprs network so i know that the software has worked...  :)
I will sent you if you want screenshots from my monitor :)
This data from Alex ive seen in the aprs net:
2018-09-25 15:32:49 - 2021-04-07 04:38:49
radmon.org 15.5 CPM 0.09 uSv/hr Average 19.5 Max 29.5 Min 10.3
[APRS via TCPIP*,qAC,T2CZECH]
Thank you very very much for your help !!!
73 and 55
Carsten
Log Port 80:
Nmap scan report for euro.aprs2.net (94.33.51.3)
Host is up (0.073s latency).
Other addresses for euro.aprs2.net (not scanned): 51.210.15.145 85.90.180.26 185.193.11.155 62.77.224.245 89.228.59.72 86.123.190.5 85.214.83.187
4 years 8 months ago #5961 by mw0uzo
Ok I have set up here and it's working, you can check my call MW0UZO on aprs.fi
There is one thing I have forgotten from the above setup instructions: Your latitude and longitude must be set in the radmon.org tab!!
I am using server uk.aprs2.net, with my call in capitals MW0UZO, the approriate key, SSID 0, the default Text and my coordinates of 51.4925, -3.2515 in radmon.org tab
Time to create page: 0.179 seconds
Solar powered Raspberry Pi 4 server stats: CPU 57% Memory 15% Swap 17% CPU temp=63.7'C Uptime 17 Days
