Report measurements to APRS via internet (only internet,not HF)
4 years 8 months ago #5987 by DG5BAA
Hello Alex !
I completely deleted radlog 0.43 and then reinstalled it, but still nothing ...
73/55
Carsten
4 years 8 months ago #5988 by gw7eri
Hi Carsten,
Well, I am really sorry that has not worked for you! Your entered coordinates will be ok as that information is taken from the same part of the software where you enter it for radmon display and your station is displayed on the radmon map.
I'm afraid I am running out of ideas now, but will continue to have a think about it and if I can find something else will post it here.
Best 73's
Alex
GW7ERI
GW7ERI
4 years 8 months ago - 4 years 8 months ago #5990 by mw0uzo
Update:
I see that the server accepts the request but i still dont see my measurements from aprs.fi...
I once set up the Bluestack Android Emulator dor APRSDruid on my Win10 computer and everythink works with it...
What can it be?
Carsten
I don't think this is an installation problem or a compatibility mode problem.
In one of your earlier screenshots, RadLog was reporting 'Error parsing APRS key'.
Radlog assumes a integer APRS key. Is your key alphanumeric? Is there an accidental space character in there?
Last edit: 4 years 8 months ago by mw0uzo.
4 years 8 months ago #5991 by gw7eri
Hi Daniel,
I'm sure you are right to be honest - my suggestions were just a 'long shot' on my part as I am running out of ideas. I feel certain the issue is at the APRS server side of things and the packets are being rejected for some reason there...
Best 73's
Alex
GW7ERI
4 years 8 months ago - 4 years 8 months ago #5992 by DG5BAA
Hello mw0uzo (daniel?)
My passcode only consists of 5 numbers written together. Perhaps I entered them incorrectly at the time of the screenshot so that this error was displayed !?
Since then I have re-entered it several times and the message has not appeared since then.
APRSDruid and UI-View32 checked that my passcode was correct.
However, I am surprised that with APRS the passwords can be read out so easily by the key generators.
I have the impression that they
APRS packets sent by Radlog 0.43 may be blocked by a filter by the server because the packets are accepted by APRS Druid and IE-VIEW ...I am of the opinion that due to the existing and coming crises this program is something very valuable and I want to contribute something to the emergency radio, so I am so interested in being able to transmit measurement data as a beacon into the APRS network ...
CU
Carsten,DG5BAA
member of:
https://www.darc.de/der-club/distrikte/y/ortsverbaende/35/
and administrator of:
https://www.repeaterbook.com/simplex_nodes/details.php?state_id=DE&ID=10286
Last edit: 4 years 8 months ago by DG5BAA.
4 years 8 months ago - 4 years 8 months ago #5993 by DG5BAA
Hello !
does it make sense to try this version out?
Unfortunately I cannot download it ... offline ?
I would like to test this version out..
www.radmon.org/RadLog-V042-ALPHA.zip
73/55
Carsten
Time to create page: 0.171 seconds
Solar powered Raspberry Pi 4 server stats: CPU 65% Memory 15% Swap 18% CPU temp=63.7'C Uptime 17 Days
