Report measurements to APRS via internet (only internet,not HF)
4 years 8 months ago #5994
Replied by mw0uzo on topic Report measurements to APRS via internet (only internet,not HF)
Can you post or PM me or email me mycall at gmail.com a screenshot of the packet with all the data in, user, key, display string etc.
There might be a clue in there as to why it's not working or being accepted by the APRS server.
RadLog does have a non-functioning radio beacon mode that generates audio packets, but there is a mistake somewhere in the implementation that means it fails to be decoded.
Several years ago, I looked for help in trying to decode the packet at a low level with linux packet radio tools to find the mistake but was unsuccessful.
Perhaps if I work backwards from my code, explaining what it does and someone else works forward from the packet radio spec we can identify what might be wrong?
The other thing I can think of is if there are any IP range bans on the APRS server that is affecting you.
4 years 8 months ago #5995
by gw7eri
Replied by gw7eri on topic Report measurements to APRS via internet (only internet,not HF)
Hi,
I've just ordered a GQ500+ counter, which I hope will be delivered later this week! I have also downloaded Radlog 4.3 onto a win10 pc. Once I have it set up I will have a go at sending APRS beacons again and let you know. The setup I used to have was a 'Netio GC' which connected to the PC via usb. I was also able to use that on Raspberry Pi ok for both Radmon site and APRS.
Good luck in the mean time!
vb 73's
Alex
GW7ERI
vb 73's
Alex
GW7ERI
4 years 8 months ago #5996
by gw7eri
Hi again,
The only other thing I have thought of at the moment is are you behind a VPN? I know when I turn mine on here it blocks my emails....
Best 73s for now and will let you know how I get on setting up the new equipment once it arrives.
Alex
GW7ERI
Alex
GW7ERI
4 years 8 months ago #5997
by gw7eri
PS - sorry, should have added that would mask the IP address possibly ??
Best 73's
Alex
GW7ERI
Best 73's
Alex
GW7ERI
4 years 8 months ago #5998
by DG5BAA
Replied by DG5BAA on topic Report measurements to APRS via internet (only internet,not HF)
Hello Alex !
I've already thought of that, but I'm not currently using a VPN or corporate network.
Thanks for the idea!
Cu
Carsten
Cu
Carsten
4 years 8 months ago #5999
by DG5BAA
Daniel !I just sent you an email with a report.
Cu
Carsten
Cu
Carsten
