My geiger doesn't seem connected
2 years 11 months ago #6641 by Danielgeiger
I conenect a new Geiger to Radmon but doesn't seem connected.
The Button: Station Enable? appears Disable.
Can anybody help me? thanks you.
2 years 11 months ago #6642 by Simomax
I have had a look through the last 10 minutes of logs and I can't see any submission from your station at all. When I search for your station name 'Danielgeiger' I get no results, except for one that was checking the donation status.
What is your setup? How are you submitting to radmon?
2 years 11 months ago #6643 by Danielgeiger
my setup:
2 years 11 months ago #6644 by Simomax
What does your code return when you submit? It should get a 'HTTP/1.1 200 OK' response when it talks to the radmon server, but seems it's not talking. Are you submitting to radmon by DNS or IP?
You should try and debug to find out why it isn't talking properly. Make sure your internet connection to your arduino is good and you have an IP address etc.
2 years 11 months ago #6645 by Danielgeiger
The truth is that I don't know if it is sending by IP or by DNS, I don't know what that means or when it is configured in the registration process, etc.
2 years 11 months ago #6647 by Simomax
Where did you get the code from for the adruino? I am assuming you have uploaded code to the arduino?
Time to create page: 0.184 seconds
Solar powered Raspberry Pi 4 server stats: CPU 63% Memory 16% Swap 17% CPU temp=65.2'C Uptime 17 Days
