My geiger doesn't seem connected
- Danielgeiger
- Junior Member
2 years 10 months ago #6755
by Danielgeiger
Replied by Danielgeiger on topic My geiger doesn't seem connected
It is working, but only with the USB cable connected, when the cable is not there I cannot access the panel and I think it does not send data.
- steadramon
- Senior Member
- Thank you received: 13
2 years 10 months ago - 2 years 10 months ago #6756
by steadramon
Replied by steadramon on topic My geiger doesn't seem connected
Now that it is set up you can use the 5V from the Geiger counter to power the D1 Mini - though I don't know how long you'll get out of 3 AA batteries.
Personally I power the CaJoe using USB wall adapter and use the 5V from the Geiger to power the D1 mini.
Also I notice that "something" is sending data to the D1 mini over your usb serial - weird
Last edit: 2 years 10 months ago by steadramon.
2 years 10 months ago #6760
Replied by Simomax on topic My geiger doesn't seem connected
@Danielgeiger, your graph is looking better today. I noticed it we to 0's last night and then offline around 00:00 UTC, but is back now and the graph looks good.
If you are able to, it would be good for you to tidy up the wiring a bit now that it is working properly. That might make it a bit more reliable. You can also run the CA JOE counter from a regular 5v power supply. You should be able to power the CA JOE using the barrel connector (PSU connector) on the board and then the ESP will get its power through the 3 wires that connect it to the CA JOE. It may be better to run it from a regular 5V PSU instead of USB as it will enable you to turn your PC off when not in use and the ESPGeiger will still submit to radmon.org using WiFi. Nice work though in getting it up and running. I suspect it's not the easiest thing for someone with little experience with these things.
Time to create page: 0.197 seconds
